Author Topic: 80 window positioning macros with keydefs and 5 misc  (Read 8764 times)
MindprisM
  • Hero Points: 8
« on: July 13, 2008, 05:52:45 AM »
Code with plenty of "bulk".
See attached
  10 1:_command void vline_pcol() name_info(','VSARG2_MACRO|VSARG2_MARK|VSARG2_REQUIRES_MDI_EDITORCTL)
  24 1:_command void line_clear_mods() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  35 1:_command void curs_down_to_mods() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  75 1:_command void curs_up_to_mods() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  116 1:_command void paste_save_pos() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  168 1:_command void winp_shl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  173 1:_command void winp_sht() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  178 1:_command void winp_shr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  183 1:_command void winp_shb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  189 1:_command void winp_sdl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  194 1:_command void winp_sdt() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  199 1:_command void winp_sdr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  204 1:_command void winp_sdb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  214 1:_command winp_sz_edge(_str d='t-')
  294 1:_command winp_sz_edge_t_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  297 1:_command winp_sz_edge_t_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  300 1:_command winp_sz_edge_b_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  303 1:_command winp_sz_edge_b_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  307 1:_command winp_sz_edge_l_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  310 1:_command winp_sz_edge_l_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  313 1:_command winp_sz_edge_r_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  316 1:_command winp_sz_edge_r_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  321 1:_command winp_sz_edge_tl_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  324 1:_command winp_sz_edge_tl_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  327 1:_command winp_sz_edge_tr_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  330 1:_command winp_sz_edge_tr_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  333 1:_command winp_sz_edge_bl_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  336 1:_command winp_sz_edge_bl_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  339 1:_command winp_sz_edge_br_less() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  342 1:_command winp_sz_edge_br_more() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  350 1:_command winp_mvs(_str d='d')
  395 1:_command winp_mv_u_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  398 1:_command winp_mv_d_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  401 1:_command winp_mv_l_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  404 1:_command winp_mv_r_s()  name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  409 1:_command winp_mv_br_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  412 1:_command winp_mv_bl_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  415 1:_command winp_mv_tr_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  418 1:_command winp_mv_tl_s() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  431 1:_command winp_mv(_str d='d')
  465 1:_command winp_mv_br() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  468 1:_command winp_mv_tr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  471 1:_command winp_mv_bl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  474 1:_command winp_mv_tl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  478 1:_command winp_mv_u() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  481 1:_command winp_mv_d() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  484 1:_command winp_mv_l() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  487 1:_command winp_mv_r() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  549 1:_command void winp_mtt() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  554 1:_command void winp_mbb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  559 1:_command void winp_mll() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  564 1:_command void winp_mrr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  570 1:_command void winp_mtl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  575 1:_command void winp_mtr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  580 1:_command void winp_mbl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  585 1:_command void winp_mbr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  591 1:_command void winp_mrt() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  596 1:_command void winp_mrb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  602 1:_command void winp_mlt() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  607 1:_command void winp_mlb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  695 1:_command void winp_full() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  701 1:_command void winp_ul() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  707 1:_command void winp_u31l() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  713 1:_command void winp_u31r() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  719 1:_command void winp_u32l() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  724 1:_command void winp_b33l() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  730 1:_command void winp_b33r() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  737 1:_command void winp_ur() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  744 1:_command void winp_br() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  750 1:_command void winp_bl() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  756 1:_command void winp_ll() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  762 1:_command void winp_lll() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  768 1:_command void winp_rr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  774 1:_command void winp_rrr() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  780 1:_command void winp_uu() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  786 1:_command void winp_uuu() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  792 1:_command void winp_bb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  798 1:_command void winp_bbb() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  827 1:_command void winp_flip_r() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  832 1:_command void winp_flip_l() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  837 1:_command void winp_flip_u() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  842 1:_command void winp_flip_d() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  875 1:_command void winp_ctr_v() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  880 1:_command void winp_ctr_h() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
  885 1:_command void winp_ctr_b() name_info(','VSARG2_MARK|VSARG2_REQUIRES_EDITORCTL)
