Author Topic: Restore Editor state on Startup - does not return to line location  (Read 6953 times)
dandunbar
Is there any plans to change the behavior of the SlickEdit editor so that when you select to have eclipse restore editor state on startup that files in SlickEdit will open to the line you had the cursor on (like the text editors supplied with eclipse do) rather than just having the cursor go to the top of the file?
