Author Topic: Problem cycling through MDI windows  (Read 2783 times)
Wanderer
  • Hero Points: 23
« on: August 05, 2008, 03:58:31 pm »
WinXP sp3, SlickEdit 13.0.1 h/f 17
"One file per window" is checked.
I regularly use Ctrl-Tab to cycle through my MDI windows.  However, when focus goes to a minimized window, Ctrl-Tab stops working.
Similarly, Ctrl-N (bound to next-buffer) produces the message 'Key not defined' when pressed when the minimized window has the focus.  It appears the only way to use the keyboard to change the focus from the minimized window is to open the Window menu, but that is very cumbersome if there are more than 9 windows open.
Rodney
  • Hero Points: 47
Re: Problem cycling through MDI windows
« Reply #1 on: August 05, 2008, 05:41:08 pm »
Confirmed. Working on a fix.
--rodney
Wanderer
  • Hero Points: 23
« Reply #2 on: August 05, 2008, 06:07:15 pm »
--rodney
Weird.  I just installed the latest h/f and SlickEdit seems to be working as expected...
Oops, nope.  Ctrl-N stops working ("Key not defined") when it gets to the minimized window.  At that point Ctrl-Tab stops working, too.
