Author Topic: Hungry delete  (Read 3492 times)
mcarlson
Hungry delete
« on: August 19, 2008, 04:31:18 pm »
I've done a search of the forums, but I am failing to find any answers.
Is there an option or macro to emulate emacs "hungry-delete" mode?
This removes all whitespace between the cursor and the previous non-whitespace char including new lines.
I tried to write a macro to do this, but have to admit that I'm not yet familiar enough with Slick-C.
BTW - is there a way to break a Slick-C macro when you write an infinite loop? :-[
Matt
  • Hero Points: 288
Re: Hungry delete
« Reply #1 on: August 19, 2008, 04:35:07 pm »
Howto break Slick-C macro code: SHIFT-CTRL-ALT-F2
Re: Hungry delete
« Reply #2 on: August 19, 2008, 06:06:42 pm »
Try gnu_delete_space command, bound to Alt-\ in default GNU Emacs emulation.  I think that's what you want.
mcarlson
Re: Hungry delete
« Reply #3 on: August 19, 2008, 08:34:43 pm »
I think I found a solution and thought I would share it for the next person who comes over from emacs.
If you see an easier way to do something I've done here, I'd love to hear about it.
#include "slick.sh"
boolean is_whitespace( _str cur_char )
   boolean ws = false;
   if( (cur_char == " ")  ||
       (cur_char == "\n") ||
       (cur_char == "\t") ||
       (cur_char == "\r") )
      ws = true;
   return( ws );
_command void hungry_delete( ) name_info(','VSARG2_REQUIRES_EDITORCTL)
   int col = p_col;
   left();
   cur_char = get_text();
   if( col > 1 ) { right();}
   if( is_whitespace( cur_char) )
      /* backspace until we find a char */
      while( is_whitespace( cur_char ) || (col == 1) )
         linewrap_rubout();
         col = p_col;
         left();
         if( col > 1) { right(); }
   else
      linewrap_rubout();
If the "Line Wrap on Text" option is selected ("Tools", "Options", "Redefine Common Keys...") hungry-delete will continue past the beginning of the current line.
Thanks for the help.
And also thanks for all the help you've given others.  The archives here are a great resource.
Matt
EDIT:
It's better if it also deletes non-whitespace chars  ::)
« Last Edit: August 19, 2008, 09:00:33 pm by mcarlson »
