Author Topic: title-less form  (Read 5010 times)
jonesa
title-less form
« on: September 07, 2006, 05:34:35 pm »
Hello,
I have been working on writting a macro with a small UI (a single dropdown). The current hurdle I am facing is that I have not been able to figure out how to make the form show up in the UI without the little title bar on it.. I would like it to behave like the context drop down or the file tab elements, and I have even copied the form specification from the context dropdown, with no luck.
Does anybody know the trick to hide that title bar?
  • Hero Points: 320
Re: title-less form
« Reply #1 on: September 08, 2006, 12:53:05 am »
In the toolbar customisation dialog, click new, then in the new toolbar dialog, click the advanced button and make sure the "sizeable" checkbox is unchecked.  For me, if this checkbox is checked, the form shows with a title bar and without it it doesn't.
