Author Topic: @PlanetPratt: Fix for Compiler Properties issue  (Read 5844 times)
Ryan
  • Hero Points: 77
« on: September 25, 2008, 04:09:28 pm »
Way back in the beta you reported a crash in the Java Compiler Properties dialog: http://community.slickedit.com/index.php?topic=3666.0 .  It started happening to me recently, and I was able to fix it.
If anyone is bothered by this they can contact support and we'll get you the fix asap.
- Ryan
PlanetPratt
  • Hero Points: 6
Re: @PlanetPratt: Fix for Compiler Properties issue
« Reply #1 on: September 25, 2008, 04:59:38 pm »
I think I'm good at the moment, but thanks for letting me know.
  (*Chris*)
