Author Topic: Help with build  (Read 5688 times)
afflictedd2
  • Guest
Help with build
« on: October 26, 2008, 02:14:08 am »
Hi guys,
I just made a very simple project, and tried to use Generic C/C++ on it. then I created a file inside the project and this is all it is:
#include <iostream>
using namespace std;
int main () {
    return 0;
When I try to compile it I get this error saying file not found (cc) but when I go to properties and set the compiler to Visual studio, I still get the same error.
C:\Users\Viper\qt\gotocell>---------- Build Project: 'gotocell.vpj' - 'Debug' ---------- VSLICKERRORPATH="C:\Users\Viper\qt\gotocell"
Dependency database not found.  Rebuilding...
main.cpp
vsbuild: File not found (cc)
*** Errors occurred during this build ***
C:\Users\Viper\qt\gotocell>C: & cd C:\Users\Viper\qt\gotocell
Any help appreciated,
Ed.
  • Hero Points: 438
Re: Help with build
« Reply #1 on: October 27, 2008, 02:48:17 pm »
You need to go to Project > Project Properties..., "Tools", and select the "Compile" command and set it to a compiler that you have.
The "Compiler" setting, as documented, only effects tagging.
