Author Topic: Project "Templates"  (Read 3646 times)
Brandon Hamm
Project "Templates"
« on: September 09, 2006, 07:04:03 am »
I have built a set of project templates for our team's project(s) that use the SCons build system.  Is it possible to distribute these customized project types (or templates, not sure what to call them) to my other team members?  If so, which file(s) should I distribute to them.
Secondly, I'm using v11.0.2, some other team members may still be using 10.x - will the file format be compatible?
Thanks in advance for the help!
Brandon
  • Hero Points: 454
Re: Project "Templates"
« Reply #1 on: September 15, 2006, 01:50:20 pm »
The templates are stored in "usrprjtemplates.vpt" in your SlickEdit configuration directory.
We have not changed the project format between 10.0 and 11.0, so your 10.0 users should be able to use your templates without difficulties.
