Author Topic: assign keybinding to menu item  (Read 2888 times)
cirocco
« on: December 18, 2008, 08:27:04 am »
Hi
  I s there a general way to assign a key to menu Item? I am trying to assign key binding to "Open files from Project", and cannot find what command it is.
  The record macro function does not work too, there is no code in the macro, and "execute last macro" does nothing.
Thanks for any help
Roman
Ding Zhaojie
  • Hero Points: 37
Re: assign keybinding to menu item
« Reply #1 on: December 18, 2008, 12:08:45 pm »
project-load -p
And you can find all menu items in the menu bar via "open-menu _mdi_menu".
cirocco
« Reply #2 on: December 18, 2008, 01:51:58 pm »
project-load -p
Thanks, it is exactly what I was looking for :-)
