Author Topic: NullPointerException at startup  (Read 6919 times)
mlindsey
« on: December 22, 2008, 05:24:50 pm »
I get a NullPointerException on startup after installing SECore 3.4.0 into Eclipse 3.4.1 under Ubuntu 8.10. It appears the editor defaults to standard Eclipse java editor so I can continue to work but without SECore. Any hints?
!SESSION 2008-12-22 09:58:31.391 -----------------------------------------------
eclipse.buildId=M20080911-1700
java.version=1.5.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86 -debug
!ENTRY org.eclipse.jface 4 2 2008-12-22 09:58:40.903
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.NullPointerException
   at org.eclipse.jface.viewers.ViewerCell.getStyleRanges(ViewerCell.java:196)
   at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider.update(DelegatingStyledCellLabelProvider.java:106)
   at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider.update(DecoratingStyledCellLabelProvider.java:134)
   at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:145)
   at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:932)
   at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeRunnable.run(AbstractTreeViewer.java:102)
   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
   at org.eclipse.core.runtime.Platform.run(Platform.java:880)
   at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
   at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
   at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:1012)
   at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:466)
   at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2041)
   at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:827)
   at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:802)
   at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
   at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:776)
   at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:634)
   at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1490)
   at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:823)
   at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1474)
   at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1365)
   at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:397)
   at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1328)
   at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$PackageExplorerProblemTreeViewer.preservingSelection(PackageExplorerPart.java:353)
   at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1467)
   at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:251)
   at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1603)
   at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.createPartControl(PackageExplorerPart.java:588)
   at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:371)
   at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:230)
   at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
   at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:306)
   at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:531)
   at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
   at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
   at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
   at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
   at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
   at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:668)
   at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
   at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
   at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:271)
   at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:964)
   at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2593)
   at org.eclipse.ui.internal.WorkbenchWindow$25.run(WorkbenchWindow.java:2873)
   at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2854)
   at org.eclipse.ui.internal.WorkbenchWindow$19.runWithException(WorkbenchWindow.java:2171)
   at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
   at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
   at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
   at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3378)
   at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3036)
   at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
   at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1361)
   at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
   at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
   at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
   at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
   at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
   at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
   at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
   at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:585)
   at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
   at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
   at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
   at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Ryan
  • Hero Points: 77
Re: NullPointerException at startup
« Reply #1 on: December 22, 2008, 06:28:09 pm »
Hmm, well there isn't any SlickEdit class in that trace.  Even though you get an NPE, is Core active?  Does Help > About SlickEdit Core work?  What happens if you start Eclipse with a new workspace?
- Ryan
mlindsey
« Reply #2 on: December 22, 2008, 08:55:57 pm »
Well, it works just fine when I use a clean workspace. Thanks!
