Author Topic: Flex Support Plug-in for SlickEdit Core 3.4.0  (Read 11425 times)
jjones
  • Guest
« on: February 10, 2009, 07:33:18 PM »
A patch for users of SlickEdit Core for Eclipse 3.4.0 in either Flex Builder 3 or the Flex Builder 3 Eclipse Plug-in has been released.  The patch improves the usability of the SlickEdit editor while debugging Flex applications:
*  Set breakpoints in ActionScript and MXML files in the SlickEdit editor.
*  Use Slick-C debugging commands (debug_step_over, debug_step_into, etc.) while debugging Flex apps.
*  See Flex build error markers in the SlickEdit editor.
*  Fix for problem involving smarttab and "Use continuation indent on function parameters" option
*  Tagging support for this.
*  Proper auto-indenting on default: statement in switch/case statements
Download the attached zip file and extract to a local directory.  The readme.txt contains installation instructions.
« Last Edit: February 27, 2009, 07:33:28 PM by Jason »
