Author Topic: tag files  (Read 3990 times)
jf
tag files
« on: September 21, 2006, 07:39:44 am »
I just changed from VisualSlickEdit v4 to SlickEdit v11 and can't find a way to create a tag file
for PV-WAVE. Has been working ok with the old version. At version 11 this language should be
supported for context tagging and the help system tells me that the tag file is created automatically.
I'm afraid it isn't. May be this is a stupid question but I have no idea what to do.
  • Hero Points: 467
Re: tag files
« Reply #1 on: September 21, 2006, 02:05:16 pm »
It looks like the support macro for PV-WAVE is installed in V11 but not loaded.  Go to Macro->Load Module... and specify pro.e in the macros directory.
jf
Re: tag files
« Reply #2 on: September 22, 2006, 08:09:07 am »
This was a great hint: thanks, now it's working!
