Author Topic: Switch between open/project/workspace files panes with same macro  (Read 6776 times)
Bock
Command Name:
activate-files-nextpane
Written For:
SlickEdit 12.0.3.0
Description:
Alternatively activate either one of open/project/workspace files panes.
Switch to the next pane when activating the macro while the 'Filter' field is focused. If not focused, focus the current pane but do not switch it.
Basically the idea is to map this to a key so you can easily switch between those panes with a single hotkey.
Installation:
Save the macro file locally and load it via Macro > Load.
