Author Topic: Export options zip file is invalid  (Read 3480 times)
  • Hero Points: 335
« on: March 22, 2009, 08:28:55 am »
In the Slick 2009 latest release on WinXP SP3, the export options feature creates an invalid zip file that neither slickedit options import or anything else I have can open.  I tried emailing this to support but it got rejected due to the zip file attachment.
Sandra
  • Hero Points: 36
Re: Export options zip file is invalid
« Reply #1 on: March 23, 2009, 01:41:27 pm »
I was able to open the zip file using the Import Options feature.  All it had in it was some spell check options - is that accurate or did you have more options on there?
We are aware of the problem with opening these zip files outside of SlickEdit.
  • Hero Points: 335
« Reply #2 on: March 23, 2009, 08:38:52 pm »
Hmm, it opens ok for me now too.  I had guessed that despite the extension, it wasn't a normal zip file but when I tried importing it I got an error dialog  - however, I think what happened was that I clicked on the key bindings dialog "import" button (in haste) and got an "invalid document structure" dialog.  Sorry about that!
  • Hero Points: 466
« Reply #3 on: March 23, 2009, 11:52:57 pm »
This will be fixed in the next update.
