Author Topic: Export to HTML - No Help  (Read 4432 times)
Tim Kemp
  • Hero Points: 91
« on: March 24, 2009, 12:48:58 pm »
I'm using SlickEdit 2009 on XP SP3.  I clicked on the Help button in the Export to HTML dialog and got the attached message.
SlickEdit Support
  • Hero Points: 26
Re: Export to HTML - No Help
« Reply #1 on: March 24, 2009, 06:22:35 pm »
Hi there,
Thanks for the heads up!  And in case you didn't find it in the actual Help dialog:
Exporting to HTML--To save the current open buffer as HTML file with formatting and color coding, from the main menu, click File → Export to HTML (or use the export_html command).
Best,
SlickEdit Support
Scott H
  • Hero Points: 9
« Reply #2 on: March 24, 2009, 08:15:58 pm »
This is fixed for the next release, thanks for letting us know about that.
Tim Kemp
  • Hero Points: 91
« Reply #3 on: March 24, 2009, 08:20:51 pm »
Glad to be of assistance.  By the way, this is a nice feature, I just stumbled across it today.
