Author Topic: extension specific saves w/o trailing spaces  (Read 3856 times)
witness9
« on: September 22, 2006, 11:28:42 pm »
Our project normally uses 'strip-trailing-spaces' on Save.  However, one file type we use needs each line to end in a space.  I created a simple macro that seems to work OK to save w/this parameter off and then reset it:
_command save_wo_strip()
  def_save_options='... -S ...';
  execute('save','');
  def_save_options='... +S ...';
  return(0);
I couldn't find what parameter to change, so I started by recording the steps and then cutting out what I supposed were unnecessary steps.  Is there a better way?
More importantly, is there a way to make this the way all files with a certain extension are saved automatically?
Phil Barila
  • Hero Points: 61
Re: extension specific loads w/o converting tabs?
« Reply #1 on: September 23, 2006, 01:36:56 am »
While we're at it, could SE maybe make "Expand tabs to spaces" an extension-specific behavior?  It would make the occasional makefile wrangling a lot less of a hassle when I that file option is selected.
  • Hero Points: 428
Re: extension specific saves w/o trailing spaces
« Reply #2 on: September 25, 2006, 04:25:42 pm »
No way to do this yet.  I'll file a feature request.  The real work here is in modifying the Extension Options dialog.
The build_load_options() macro function handles almost all load/save options.  This is where any new extension specific load/save options would have to be processed.  This would be pretty trivial code.
