Author Topic: Macro to find VHDL assignments (easily modified for other languages)  (Read 7293 times)
Gardener
The following macro looks at the word under the cursor and searches from the beginning of the file to find a VHDL assignment. For example, if the cursor is on SignalName, executing the macro will find:
SignalName<=
SignalName <=
SignalName:=
SignalName :=
with any amount of white space between the signal name and the assignment operator. VHDL has two types of assignment operators, which is why they both are searched. The macro allows you to align your code for easier readability, yet quickly find all assignments (as compared to usage) of the signal.
You can easily change the assignment operator to match the specifics of the language.
Many thanks to Graeme who got me started.
Gardener
_command VhdlAssign() name_info(','VSARG2_MACRO|VSARG2_REQUIRES_MDI_EDITORCTL)
   int k;
   typeless p;
   save_pos(p);
   _str s = cur_word(k);            // grab the word at the cursor
   _str SignalAssign = " *<=";      // assignment operator for signals in VHDL
   _str VariableAssign = " *:=";    // assignment operator for variables in VHDL
   _str SearchOptions = "PUW";      // P = Wrap to beginning/end when string not found; U = Unix regular expression; W = full words
   if (s != '')
      top();
      if (find(s :+ SignalAssign, SearchOptions) == 0)        // check to see if a signal assignment can be found
        return 0;
      else if(find(s :+ VariableAssign, SearchOptions) == 0)  // check to see if a variable assignment can be found
        return 0;
   restore_pos(p);                                            // no match found, so go back to original cursor position
   // echo warning message
   message("Find(" :+ s :+ SignalAssign :+ ", " :+ SearchOptions :+ ") or Find("  :+ s :+ VariableAssign :+ ", " :+ SearchOptions :+ ") unsuccessful");
   return -1;
