Author Topic: The dialog background is black !!!  (Read 4207 times)
zhishupp
« on: May 14, 2009, 05:19:14 pm »
the background of the SE dialog is black, I can not read what on it...
how can I solve this problem..
tks!
ScottW, VP of Dev
  • Hero Points: 64
Re: The dialog background is black !!!
« Reply #1 on: May 14, 2009, 06:23:33 pm »
We're going to need a bit more information on this one: which dialog, what version, what platform...
zhishupp
« Reply #2 on: May 15, 2009, 03:30:15 pm »
ver = 14.0.0.7
platform = win32
dialogs = for example: project properties  --- in attach
ScottW, VP of Dev
  • Hero Points: 64
« Reply #3 on: May 15, 2009, 04:09:20 pm »
The colors for dialogs, like the one you posted, are set by the operating system. They should be the same as are used by Windows Explorer or any other application on your system. See the attached picture from my Windows XP system.
I'm going to assume that SlickEdit looks different from your other applications, but just in case you can change those colors as follows: right-click on your desktop and select "Properties" to bring up the Display Properties dialog. Select the Appearance tab and click the Advanced button.
Instead of setting individual colors, you might try switching to a different color scheme (also on the Appearance tab) to see if SlickEdit is still black. Then switch back if you prefer the original.
If that doesn't work, you might try rebooting your system. If none of this helps, let us know. Something odd is definitely going on here.
chrisant
  • Hero Points: 131
« Reply #4 on: May 15, 2009, 05:20:54 pm »
ver = 14.0.0.7
platform = win32
The platform is Win32?  Which version of Windows?  The button shapes do not look like any version of Windows.  Is it native Windows, or is it a Windows emulation package on another OS?
Are you running WindowBlinds or another theming program?  If so, what happens if you turn it off and let Windows natively draw the stuff?
zhishupp
« Reply #5 on: May 16, 2009, 03:39:34 pm »
Tks for ScottW, after I changed my OS theme to the native, It's go right!~
It's due to the new OS theme.....
Thank you very much
tks chrisant too..
