Author Topic: Error from install  (Read 4007 times)
Gavin Melville
Error from install
« on: June 03, 2009, 04:34:22 am »
Hi,
When trying to install SlickEdit core into Eclipse 3.4 I get a
Unsatisfied dependency: [com.slickedit.windows.feature.feature.group 3.4.0] requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.debug.ui/0.0.0
This would seem to be a Eclipse problem, likely from searching the net a java one, but does anyone have a simple answer ?
Regards,
Gavin Melville.
Ryan
  • Hero Points: 77
Re: Error from install
« Reply #1 on: June 03, 2009, 01:45:59 pm »
Core 3.4.0 (and earlier) requires the JDT.  You should be able to dl/install it through Help > Software Updates > Available Software.  The Ganymede site should already be in this list, and the JDT should be under the category "Java Development".  This dependency has been removed for 3.5.0...the JDT will only be required for Java development.
Hope this helps.
- Ryan
