Author Topic: Consistancy: Can you make ESC close Smart Open?  (Read 3463 times)
greggman
  • Hero Points: 14
« on: July 30, 2009, 08:50:49 pm »
Most dialogs throughout Windows and slickedit I can dismiss by pressing ESC.  I bring up the search dialog by accident, I press ESC it goes away.
But, when I bring up the Smart Open dialog, pressing ESC does not get rid of it.
I suppose the reason is smart open is a panel although I pulled it out of the panel. In the panel it is too thin to be useful since I can't see the paths.  Out of the panel thought it doesn't behave like a dialog.
Suggestion:
How about, if a panel is undocked then pressing ESC closes the panel?
Rodney
  • Hero Points: 54
Re: Consistancy: Can you make ESC close Smart Open?
« Reply #1 on: July 30, 2009, 08:55:22 pm »
View>Toolbars, Toolbars tab
Select 'Open" tool window
Select 'ESC dismisses floating window'
--rodney
ScottW, VP of Dev
  • Hero Points: 64
« Reply #2 on: July 30, 2009, 10:01:09 pm »
I was curious, so I tried a default configuration, and that checkbox is checked by default for the Open tool window.
chrisant
  • Hero Points: 131
« Reply #3 on: July 30, 2009, 11:25:34 pm »
Yep.  But upgrading from an existing installation didn't set the "ESC dismisses..." flag.
I recently went through and set it for a bunch of toolbars, myself.
greggman
  • Hero Points: 14
« Reply #4 on: July 31, 2009, 06:15:00 am »
Awesome!!!!  Love slickedit  :D
