Author Topic: [SOLVED] using sub_str in a forum post doesn't work (with no underscore)  (Read 11430 times)
  • Hero Points: 347
This is a request to "slick team".
Is it possible to get the forum software/ setup fixed so that it doesn't reject posts that have the word s.u.b.s.t.r in them.  It is somewhat disconcerting when you write a long post, then have an error message come up (method not supported) when you try to post it.  A while ago I checked on the simple machines forum about this problem and was told it must be something specific to the slickedit forum.
« Last Edit: November 06, 2009, 11:08:55 AM by Graeme »
  • Hero Points: 347
Re: using sub_str in a forum post doesn't work (with no underscore)
« Reply #1 on: October 03, 2009, 12:22:55 AM »
Just wondering if substr works yet, since the SMF revision has gone up.
Edit : hey , it works now!    :)
