Author Topic: push_tag function do not work well  (Read 2669 times)
zhuizhuhaomeng
« on: August 10, 2009, 08:56:34 am »
I would like to use push_tag | f  to find the function in the c source code.
Most of the time it work well. But when the function is already in the open buffer,  especially in the current buffer, it does not work properly.
  • Hero Points: 291
Re: push_tag function do not work well
« Reply #1 on: August 10, 2009, 09:55:54 am »
As a good rule of thumb you should post support requests/bug reports in a way that also YOU would be able to handle it.
So basically 'something is wrong' without any describing detail doesn't help a lot.
See a 'reference' bug report here.
Please add steps to reproduce if possible, actual vs. expected behaviour and SE version/platform to help the SlickTeam and/or others to help you.
