Hello Slickteam,
there is little problem when using
4nt (
http://jpsoft.com) as (better) console on windows (WXP-SP2).
If using it executing build scripts etc. the ntpinit window is restored.
To be clear - everything is working fine. Except the annoying window popping up
Maybe ntpinit should ignore some more
WM_ msgs or at least never unhide.
A fix would be really great !
