Author Topic: Problem about project dependency detection.  (Read 4043 times)
ablmf
  • Guest
« on: October 20, 2009, 06:39:59 am »
I create two project in slickedit, A is for exe, the other, B,  is for a static library.  A have to link B.
In project dependency, I checked the option to have A depends on B.  So when B is modified, A is compile again.
BUT, I found that slick edit could not detect that the libB.a is modified, so it doesn't re-link A.
The only way is to rebuild A completely.
What mistakes did I made?  Or it's the only way to handle static libraries?
Re: Problem about project dependency detection.
« Reply #1 on: October 20, 2009, 08:59:09 pm »
Could you provide more info?  If you could zip up the workspace and project and attach it here, it would help if we knew exactly how your projects are configured.
« Last Edit: October 20, 2009, 09:00:52 pm by Lee »
ablmf
  • Guest
« Reply #2 on: October 27, 2009, 04:38:54 am »
I can not give you the source code, but I can give you the workspace and project file.
ablmf
  • Guest
« Reply #3 on: October 27, 2009, 04:43:04 am »
In the workspace, you can see that project vivs_hvr_test depends on vivs_hvr, and vivs_hvr depends on vivs_core.
« Reply #4 on: October 27, 2009, 02:04:08 pm »
Project and workspace look correct,  I can't see any obvious problems.  As long as the project with the dependencies is the active project, it should rebuild the dependent projects.  There could be a problem with the dependency generation in the build.  You might want to delete any *.vpb files in the Debug/Release directories, and do a complete rebuild.  That will ensure that the dependency files are up-to-date.
