Author Topic: key bindings helper  (Read 8890 times)
  • Hero Points: 325
key bindings helper
« on: January 09, 2010, 11:13:01 pm »
I've been re-organizing my keybindings so I can try and remember them more easily.  In the process, I wrote some macros that let me see the key bindings in groups  e.g. all key bindings involving the same function key are grouped together.
The macro xkey_bindings_show generates a file group-keydefs.e in your config-folder/keybindings folder  - just like the list-keydefs command generates keydefs.e.  Unlike keydefs.e, the group-keydefs.e file is not intended to be loaded.
The macro xkey_binding_trainer prompts for a key, then displays a menu of the "key group" and associated commands.  e.g. press F1 and you get a menu of F1, S-F1, C-F1 etc.  You can execute a command from the menu as well as use it to jog your memory.
It does not handle "composite" key sequences.
e.g. this is what I currently have for the enter key
  'ENTER'=         split_insert_line;
  'S-ENTER'=       keyin_enter;
  'C-ENTER'=       nosplit_insert_line;
  'A-ENTER'=       what_is;
  'C-S-ENTER'=     nosplit_insert_line_above;
  'A-S-ENTER'=     where_is;
  'C-A-ENTER'=     xkey_binding_trainer;
  'C-A-S-ENTER'=   xkey_bindings_show;
The macro works for me but there's no guarantee it will work for you so if you have a problem, post it back here and maybe someone can fix it!
Command Name:
xkey_bindings_show
Written For:
SlickEdit 14
Description:
See above
Limitations:
Does not handle "composite" key sequences.
Outputs key bindings for "default" mode only.
Installation:
Save the macro file locally and load it via Macro > Load module.
« Last Edit: October 30, 2016, 01:36:03 am by Graeme »
  • Hero Points: 325
Re: key bindings helper
« Reply #1 on: January 11, 2010, 04:01:02 am »
Fixed a problem where the xkey_bindings_show command didn't work properly if the group-keydefs.e file didn't already exist.  Previously, the group-keydefs.e file would get created if it didn't exist but would be left empty so you would have to run the command twice to get it to work.
WadeHatler
  • Been using VSlick since the dawn of time
« Reply #2 on: August 17, 2012, 06:12:10 pm »
Very handy.  Thanks.
jlynker
« Reply #3 on: September 14, 2012, 08:16:31 pm »
+1, very helpful.
Had to create directory:
"%USERPROFILE%\My Documents\My SlickEdit Config\17.0.2\keybindings"
  • Hero Points: 325
« Reply #4 on: October 30, 2016, 01:37:24 am »
I've updated the file and fixed the problem of when the keybindings directory doesn't exist.
