Author Topic: FTP Site Configuration  (Read 5281 times)
rschaeff
« on: January 19, 2010, 12:59:40 am »
I am re-installing my slickedit installation from an old workstation to a new one (work splurged and upgraded my old beast).
I have dozes of ftp site profiles  (from FTP->OPEN) saved for many machines with slickedit.  Does anyone know of a way from me to export/import or copy a configuration file over that contains that information?
I poked around but did not see an *.ini for *.cnf type file... Any pointers would be appreciated as many of these are to various mainframes and I've figure out particulars for each OS/platform.  (Actually Slickedit is probably the best ftp client backend I've used)
Note: I am running on Slickedit v8... I don't see a config directory.  Copying over files (if I know which ones should be acceptable as the platform type and version of slickedit is the same.
Rick
« Last Edit: January 19, 2010, 01:25:26 am by rschaeff »
rschaeff
Re: FTP Site Configuration
« Reply #1 on: January 19, 2010, 01:49:42 am »
Found my own answer...
Under Documents,  My Visual SlickEdit Config directory.  I was lookng in Program Files and Admin/Application data....
Sorry guys, but I'll post this reply just in case some else has the same question.
