Author Topic: Toolbar Arrangement  (Read 11402 times)
HelAu
Toolbar Arrangement
« on: June 30, 2006, 07:26:36 am »
Hello,
I'd like to move the toolbar to the right of the Menu, for not wasting a separate line :)
But unfortunately this seems to be impossible.
When I move the toolbar down to th classe/Projects Window it will be alligned vertical instead of horizontal :(
Is there a way to place the toolbar without wasting space for the editing window ?
Thanks in advance
Helmut
Exolon
  • Hero Points: 5
  • https://blog.mdb977.de/
Re: Toolbar Arrangement
« Reply #1 on: June 30, 2006, 07:44:47 am »
Unfortunately you are right. The Toolbar can't beplaced above / under the Projects/Classes Tab in that way. What you may alternatively consider: It is possible to change toolbar button size to small within Toolbar Customize Dialog, so you will have some pixel more space for your edit window.
HelAu
« Reply #2 on: June 30, 2006, 09:55:31 am »
Surely I have changed the size already :) Hopefully they will add an enhancemnet in that area soon ...
