Author Topic: GenComment and Slickedit 14  (Read 7607 times)
RichardRutledge
« on: February 23, 2010, 04:20:58 pm »
Anyone had success in using Gary Ash's latest GenComment macro package with SlickEdit 14.0.2.2?
%parameters expansion in the function comment is causing a slick-c parameter error in the latest version.
I have rolled back to a prior verion (file dated 18 July 2007) that seems to work fine.
gary_ash
  • Guest
Re: GenComment and Slickedit 14
« Reply #1 on: February 23, 2010, 06:07:30 pm »
Hi,
I'm using it. What language are you using? can you send me a sample of code and your settings?
gb
RichardRutledge
« Reply #2 on: February 23, 2010, 07:23:40 pm »
I'm using cpp. Attached you will find a hello world cpp file, my GenComment.ini file, and a screen shot of the SE stack showing the invalid argument. The file header inserted properly, but when I placed the cursor on _tmain and invoked gc-edit, error occurs.
gary_ash
  • Guest
« Reply #3 on: February 23, 2010, 08:55:06 pm »
I'm sorry use had trouble.
Please try the attached update and let me know if you have anymore trouble.
RichardRutledge
« Reply #4 on: February 23, 2010, 09:26:30 pm »
Working!
I can't thank you enough for your generous contribution of time and talent to maintain/enhance your comment package.
