Author Topic: CppCreateImplementation  (Read 17343 times)
SlickEdit Support
  • Hero Points: 26
« on: April 08, 2010, 08:38:23 pm »
//This macro has been posted for other SlickEdit users to use and explore.
//Depending on the version of SlickEdit that you are running, this macro may or may not load.
//Please note that these macros are NOT supported by SlickEdit and is not responsible for user submitted macros.
"This command will create implementation stub functions for all the member
functions of the class the cursor is positioned within. You'll be prompted to
place the cursor in the file you want to implementation to in a press the
spacebar."
« Last Edit: April 08, 2010, 09:08:06 pm by SlickEdit Support »
