Author Topic: Fill String (Fillstr.e)  (Read 6884 times)
SlickEdit Support
  • Hero Points: 29
« on: April 08, 2010, 08:40:03 PM »
//This macro has been posted for other SlickEdit users to use and explore.
//Depending on the version of SlickEdit that you are running, this macro may or may not load.
//Please note that these macros are NOT supported by SlickEdit and is not responsible for user submitted macros.
This macro fills a column block with a mult-character string. This is somewhat similar to fill_selection() except that you are not limited to filling the block with a single character and can fill it with multiple characters.
« Last Edit: April 08, 2010, 09:07:49 PM by SlickEdit Support »
