Author Topic: Auto-formatting for lisp like emacs.  (Read 6724 times)
SlickEdit Support
  • Hero Points: 29
« on: April 08, 2010, 08:52:04 PM »
//This macro has been posted for other SlickEdit users to use and explore.
//Depending on the version of SlickEdit that you are running, this macro may or may not load.
//Please note that these macros are NOT supported by SlickEdit and is not responsible for user submitted macros.
"This is an attempt to do some of the auto-formatting for lisp that emacs does because basically it's nearly impossible to program in lisp unless you have the editor help you by forcing your formatting and as I hate emacs I needed to get SlickEdit to do this for me."
« Last Edit: April 08, 2010, 09:06:42 PM by SlickEdit Support »
