Author Topic: quick find  (Read 3981 times)
afflictedd2
  • Guest
quick find
« on: April 23, 2010, 08:34:12 pm »
Hi everyone,
I find it sometimes annoying to select copy, open the dialog box to find, paste and press enter to find a word I am looking for, I was wondering if one could build a macro to quickly highlight the word that the cursor is in copy it and paste it and show all results.
woopsies.. just found there's a quick-search command bound to CTRL F3 to do this.
Ted.
« Last Edit: April 23, 2010, 08:35:56 pm by afflictedd2 »
LBCEi
  • Hero Points: 20
Re: quick find
« Reply #1 on: April 24, 2010, 12:04:52 am »
There is also an option (Tools->Options->Editing->Search) to use the word at cursor to initialize the search string in the normal search dialog.
Les
