Author Topic: How to expand/collapse function with hotkey ?  (Read 17880 times)
inventec
« on: October 26, 2006, 02:44:57 AM »
In c files, used by function heading/show all which in view menu, we can view or edit program simply .
Sometimes, I always double click the heading icon(+/-)  for processing one function only, because I don't know what is hotkey .
It's so trouble .
Somebody who knows it tell me how to do it, please !
Thank you !
  • Hero Points: 292
Re: How to expand/collapse function with hotkey ?
« Reply #1 on: October 26, 2006, 07:40:05 AM »
Bind a key to 'plusminus'.
at5dapa1
  • Hero Points: 24
« Reply #2 on: October 26, 2006, 09:27:04 AM »
Thanks HS2, indeed very useful to know this!
By the way, do you know if is possible to instruct SE, to open by default any file in "Selective Display" mode?
  • Hero Points: 347
« Reply #3 on: October 26, 2006, 10:11:45 AM »
Wow.  You're a master of SlickEdit HS2!  :)
I hope the SE doc team is reading this thread coz plusminus doesn't appear in the help anywhere!
Wanderer
  • Hero Points: 23
« Reply #4 on: October 26, 2006, 01:05:58 PM »
I think you would have to write a hook macro (I think it would be in the form _buffer_add_xxxx, but I can't remember), and then call one of these functions:
all
allnot
hide_all_comments
hide_code_block
hide_selection
preprocess
selective_display  // probably don't want this one - it activates the GUI dialog
show_all
show_braces
show_col1
show_current_proc
show_indent
show_paragraphs
show_procs
show_selection
« Last Edit: October 26, 2006, 01:13:36 PM by Wanderer »
alex
  • Hero Points: 6
« Reply #5 on: October 26, 2006, 01:13:19 PM »
If you want to know more about writing hook functions, check out http://community.slickedit.com/index.php?topic=84.0
You might find, e.g.,  the _buffer_add hook useful.
  • Hero Points: 292
« Reply #6 on: October 26, 2006, 03:50:13 PM »
Just a simple example to make life easier...
_switchbuf_selective_display(...)
   _str ext = get_extension(p_buf_name, false);
   switch ( ext )
      case 'cpp':
      case 'c':
         show_procs ( );
         break;
      case 'h':
         hide_all_comments ( );
         break;
      default:
         break;
Didn't check if _buffer_add_(selective_display) is also doing well.
  • Hero Points: 347
« Reply #7 on: October 26, 2006, 10:45:04 PM »
In case you didn't know, in Tools -> options -> general, if you enable the auto restore option of "selective display", slick will open a file with selective display active if that's what it had when it was closed.
inventec
« Reply #8 on: October 27, 2006, 01:03:36 AM »
HS2,
So useful, thanks very much !
cmb99
« Reply #9 on: January 18, 2007, 05:07:56 PM »
I can't think of another editor where you have to double-click the plus sign to expand. Also, I am very new to slickedit. How do you put the slick-c macro into the hook for default folding?
  • Hero Points: 292
« Reply #10 on: January 18, 2007, 06:07:35 PM »
If you just want to single click to expand/collapse... see the attached config screenshot.
cappy2112
« Reply #11 on: January 18, 2007, 08:00:01 PM »
Ive tried calling plusminus from the slick cmd line- it doesn't toggle the + or - signs
What am I doing wrong?
  • Hero Points: 292
« Reply #12 on: January 18, 2007, 08:12:56 PM »
1. 'Selective display' has to be activated first -> (+) and/or (-) signs visible on the left gutter
2. cursor sits on a line which is 'marked' with (+) or (-)
cappy2112
« Reply #13 on: January 19, 2007, 01:52:49 AM »
I've already applied Selective Display to a file, and was wondering if there is a way to fold/unfold all, as opposed to one at a time.
  • Hero Points: 292
« Reply #14 on: January 19, 2007, 12:26:16 PM »
'show-all' on cmdline or 'View->Show All' ends selective display.
