Author Topic: tag info for a typedef enum  (Read 15649 times)
murali
Re: tag info for a typedef enum
« Reply #15 on: May 12, 2010, 10:12:29 PM »
You could also have a look at this macro.
Especially the function maybe_add_return_type called e.g. by init_tree could be helpful.
The optional return type (see context menu) for enums is their value as provided by the tagging engine.
Good luck, HS2
Thanks! That macro helped quite a bit!! Now I am able to draw a tree for enums and structs with this..For those who are interested:
static _command int GetParent(_str childtype = "enumc", struct VS_TAG_BROWSE_INFO &cm = null) name_info(',')
   int context_id;
   _str class_name = cm.class_name;
   _str member_name;
   _str type_name;
   tag_split_class_name(cm.class_name, member_name, class_name);
   context_id = tag_find_context(member_name,true,true);
   while (context_id > 0)
      tag_get_context_info(context_id,cm);
      if(cm.type_name == "typedef")
         _str temp[];
         split(cm.return_type," ",temp);
         type_name = temp[0];
      else
         type_name = cm.type_name;
      if((childtype == "enumc" && type_name == "enum") ||
         (childtype == "var" && type_name == "struct")) break;
      context_id = tag_next_context(member_name,true,true);
   return context_id;
_command void DrawTreeMembers() name_info(',')
   struct VS_TAG_BROWSE_INFO cm;
   struct VS_TAG_BROWSE_INFO child_cm;
   int context_id,id ,line_no, tag_flags;
   _str file_name, class_name, type_name;
   _UpdateContext(true);
   int status = tag_get_browse_info("", cm,true);
   if(!status) {
      context_id = tag_find_context(cm.member_name,true,true);
   /* If it is a enumc or a var; get the tag info for enum */
   switch(cm.type_name)
   case "enumc":
   case "var":
         context_id = GetParent(cm.type_name,cm);
         break;
   say(cm.member_name);
   for ( id = context_id; id < tag_get_num_of_context(); id++) {
      tag_get_context_info(id,child_cm);
      if(cm.line_no <= child_cm.line_no && cm.end_line_no >= child_cm.line_no)
         if(child_cm.member_name != cm.member_name) {
            say(" +---"child_cm.member_name);
      else
         /* We are done */
         break;
