Author Topic: Manual install  (Read 4049 times)
fpefpe
Manual install
« on: May 18, 2010, 01:12:33 am »
Hello -- I was having a problem with the eclipse install for slickedit .... I downloaded the zip file -- how its it installed?
just  unzip it in to eclipse plugin directory?
thanks
Frank
Ryan
  • Hero Points: 77
Re: Manual install
« Reply #1 on: May 18, 2010, 01:31:13 am »
The zip file for SlickEdit Core 3.5?  You don't unzip it to install...you just use the Eclipse software update mechanism and point to the zip file instead of pointing to the web site URL.  In Eclipse, go to Help > Install New Software and click Add.  Click Archive and browse to the downloaded zip file, then click OK.  From there you should be able to select the feature and follow the wizard to complete the install.
- Ryan
fpefpe
Re: Manual install
« Reply #2 on: May 18, 2010, 02:01:36 am »
Thanks for the info
