Author Topic: How should I do with __read_mostly in linux kernel/Ÿ  (Read 5512 times)
zhuizhuhaomeng
« on: May 30, 2010, 08:11:56 am »
just like the code below,the slickedit can not parse the code correct,so the color will not show right.
And goto-definition will not work well.
Is there someone can solve the problem ?
static struct kmem_cache *skbuff_head_cache __read_mostly;
static struct kmem_cache *skbuff_fclone_cache __read_mostly;
        struct kmem_cache *cache;
        struct skb_shared_info *shinfo;
        struct sk_buff *skb;
        u8 *data;
        cache = fclone ? skbuff_fclone_cache : skbuff_head_cache;
        /* Get the HEAD */
        skb = kmem_cache_alloc_node(cache, gfp_mask & ~__GFP_DMA, node);
        if (!skb)
                goto out;
  • Hero Points: 291
Re: How should I do with __read_mostly in linux kernel/Ÿ
« Reply #1 on: May 30, 2010, 10:38:59 am »
Try to hide non-std. compiler extensions from tagging using the 'C/C++ preprocessing' config.
e.g. add '#define __read_mostly' and update tag DB.
PS: Use png/jpg/etc. instead of bloated bmp for images ;)
zhuizhuhaomeng
« Reply #2 on: May 31, 2010, 02:37:29 am »
Thank you very much!
