Author Topic: ToDo List Toolbar (Updated for SE2022)  (Read 78943 times)
dunkers
  • Hero Points: 36
Re: ToDo List Toolbar (Updated for SE2022)
« Reply #60 on: October 20, 2022, 10:25:06 PM »
Thank you Marty and Clark  :)
MartyL
  • Hero Points: 29
  • Synergex
« Reply #61 on: October 20, 2022, 10:27:35 PM »
this will work:
#require "se/messages/Message.e"
Most of the time #import works but there are times you need more type definitions (class/struct/enum).
Definitely looks like #require is the better answer.
AGodfrey
« Reply #62 on: June 26, 2023, 09:10:15 PM »
Very nice tool, thanks!
One suggestion: Add support for pressing 'Enter'. I added this to my copy:
todo_tree.enter() {
    todo_tree.GoToToDo();
