Author Topic: How to get SlickEdit error log  (Read 4741 times)
lzimprint
« on: June 17, 2010, 11:01:01 am »
Hi,all
I install slickedit-plugin (3.3.1)  in workbench 3.2 (basic eclipse 3.5.1),when I try to debug ,the workbench crashed. I check the error log and found it was the slickedit 's problem but the information in error log about the problem  is unspecific. How can I get specific error log about the slickedit .thanks
---.metadata/.log --
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NoSuchMethodError: java.lang.String.isEmpty()Z
at com.slickedit.eclipse.SlickEditPlugin$1.pageActivated(SlickEditPlugin.java:91)
at org.eclipse.ui.internal.PageListenerList$1.run(PageListenerList.java:68)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.PageListenerList.fireEvent(PageListenerList.java:53)
at org.eclipse.ui.internal.PageListenerList.firePageActivated(PageListenerList.java:66)
at org.eclipse.ui.internal.WorkbenchWindow.firePageActivated(WorkbenchWindow.java:1361)
at org.eclipse.ui.internal.WorkbenchWindow.access$10(WorkbenchWindow.java:1352)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:2966)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2946)
at org.eclipse.ui.internal.WorkbenchWindow$21.runWithException(WorkbenchWindow.java:2263)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.windriver.ide.application.CopyOfIDEApplication.start(CopyOfIDEApplication.java:158)
at com.windriver.ide.application.UnifiedSWTSwingApplication.access$101(UnifiedSWTSwingApplication.java:50)
at com.windriver.ide.application.UnifiedSWTSwingApplication.start(UnifiedSWTSwingApplication.java:70)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
at org.eclipse.equinox.launcher.WRWBMain.main(WRWBMain.java:51)
Ryan
  • Hero Points: 77
Re: How to get SlickEdit error log
« Reply #1 on: June 17, 2010, 01:56:53 pm »
Are you sure you are using Core 3.3.1?  This is the error you would get if you were trying to run Core 3.5.0 with Java 5 or earlier...Core 3.5.0 has a dependency on Java 6.  Core 3.5.1 no longer requires Java 6.
Could you post the whole .log file here?  Can you also show me what SlickEdit plug-ins are listed on the Plug-ins tab at Help > About Eclipse SDK, Installation Details?  You can just sort by Provider and screenshot the dialog so that I can see anything that is provided by "SlickEdit Inc.".
- Ryan
« Last Edit: June 17, 2010, 02:06:15 pm by Ryan »
lzimprint
« Reply #2 on: June 22, 2010, 08:00:26 am »
Hi,Ryan
Sorry for  reply late .
I have found jre was java 5 ,so now I update jre to java 6 ,It works fine .thanks.
