Author Topic: Cancelling a long search  (Read 9309 times)
sgartner
« on: July 09, 2010, 07:50:59 PM »
How can I cancel a long "Find in Files" search?  In CodeWright I would just hit Ctrl-Break, but I have yet to find a way to cancel the search in SE.
MartyL
  • Hero Points: 29
  • Synergex
Re: Cancelling a long search
« Reply #1 on: July 09, 2010, 07:56:38 PM »
If you open the Find dialog again, there is a "Stop" button which you can use to cancel the long search. Alternatively, you can bind a key to "stop-search" or type in "stop-search" on the SlickEdit command line.
Hope this helps,
Marty
ehab
  • Hero Points: 15
  • coding with SE is like playing music
« Reply #2 on: July 09, 2010, 07:58:40 PM »
did you try Esc key , if all fails you have the mighty ctrl+alt+shift+f2
« Last Edit: July 10, 2010, 09:21:50 AM by ehab »
sgartner
« Reply #3 on: July 09, 2010, 11:54:35 PM »
did you try Esc key , if all fails you have the might ctrl+alt+shift+f2
Wow, totally missed that "stop" button, and ctrl-alt-shift-f2 is good to know as well.  Thanks!
Tim Kemp
  • Hero Points: 92
« Reply #4 on: July 11, 2010, 02:55:40 PM »
I've noticed that the stop button is often grayed out even when the search is running.
