SlickEdit Version 15.0.0.6 Build Date: May 07, 2010
Emulation: Vim
OS: Windows 7 OS Version: 6.01.7600
Hotfixes:
C:\Users\Charles\Documents\My SlickEdit Config\15.0.0\hotfixes\hotfix_se1500_2_cumulative.zip (Revision: 2)
C:\Users\Charles\Documents\My SlickEdit Config\15.0.0\hotfixes\hotfix_se1500_7_cumulative.zip (Revision: 7)
C:\Users\Charles\Documents\My SlickEdit Config\15.0.0\hotfixes\hotfix_se1500_8_cumulative.zip (Revision:
I would like to open a VS2010 solution via SlickEdit's command line, whether or not a corresponding .vpw file exists.
When I try
vs.exe someSln.sln
SlickEdit opens the file as a text file.
Is there a switch to tell SlickEdit that the .sln should be treated as a project file?
Perhaps there is a macro I can run from the command line that would open the .sln file as a workspace?
Thanks for any tips...
