Author Topic: SE 2010 Version Control Setup  (Read 6702 times)
3JB
  • Guest
« on: July 19, 2010, 02:13:16 PM »
Hello,
I have been using SlickEdit 2010 for about 1.5 months, and it has been performing well.  Had been using 2006 or 2007 exclusively prior to upgrading.
Today, I tried to set up a new project for the first time with 2010.  Things went smoothly until I tried to set up version control with Perforce by right-clicking my project name in the project explorer and going to setup.  The "Project:" field (see attached screen shot) won't update, and therefore version control does not get set up correctly.
In another project, this has been working since installing 2010.  I tried to figure out what the settings were for this project, and now it is no longer working with Perforce, either!  I have reverted my .vpj file to its previous state, but even that does not fix it.
I installed the latest hotfix this morning as well.  I have SE version 15.0.0.6 with the hotfix_se1500_8_cumulative.zip hotfix.
Please help, this is very frustrating.
  • Hero Points: 153
Re: SE 2010 Version Control Setup
« Reply #1 on: July 19, 2010, 04:45:06 PM »
What version of Perforce are you using?
When you click "Open Project", this runs a Perforce dialog.  In some versions, rather than just selecting a depot or workspace, you have to expand it and select a file for their dialog to populate correctly, and then the project will be open when you return to the SlickEdit dialog.
  • Hero Points: 153
« Reply #2 on: July 19, 2010, 05:02:56 PM »
I think they fixed this in the most recent version, so you might want to be sure they didn't update to a version that is already outdated.
