Author Topic: Debug Other Executable on Mac OS - connection refused  (Read 3779 times)
kletskov
« on: July 22, 2010, 12:08:57 am »
I was using SlickEdit debugging GUI a lot on Linux exactly the same way -- a binary is built using some external make system, then I choose "Debug Other Executable" and go from there.
Now I need to do the same on Mac , and whatever I try , the response is "Error starting debugger - Connection refused" .  I tried changing port number for vsdebugio in settings to some random ports instead of default 8001, but this did not help.
If I start the same program and then attach to it - debugger works fine (/usr/bin/gdb)
Please advise..
Pavel.
