Author Topic: File->Save provokes Build?  (Read 3818 times)
Wanderer
  • Hero Points: 23
« on: November 03, 2006, 02:10:48 pm »
What's going on here?  It started yesterday, I think.  When I save a file (including auto-save when I switch to a different app), SlickEdit runs a Build command (not sure which one, I've got several configured).
Any ideas on how File-Save got linked to Build->Build ?!
  • Hero Points: 288
Re: File->Save provokes Build?
« Reply #1 on: November 03, 2006, 02:23:28 pm »
I think you accidentally enabled 'Build->Build Automagically on Save' ...
« Reply #2 on: November 03, 2006, 02:25:23 pm »
There is an option under Build > Build Automatically on Save (or def-var def_project_auto_build), which does exactly that.  You may have have inadvertantly enabled that option.
Wanderer
  • Hero Points: 23
« Reply #3 on: November 03, 2006, 02:26:15 pm »
Thanks, that's it.
(I wasn't even aware of that option...)
