Author Topic: How to merge one line to the remote file with SlickEdit and svn?  (Read 2884 times)
pingf
I use VisualSVN server and SlickEdit on win xp.
when I diff the file , I want to merge one line to the remote file .
but I can see the Read Only option is checked !
I have granted user the Read/Write privilege.
anybody knows why ? ???
MartyL
  • Hero Points: 27
  • Synergex
Re: How to merge one line to the remote file with SlickEdit and svn?
« Reply #1 on: October 08, 2010, 03:59:01 pm »
The checkboxes on the file difference window should show you the file's read/write state on disk. If you are positive that you have made the file writable, try doing the diff again but make sure the "Source diff" option is turned off. I think the source diff option prevents merging changes.
Hope this helps,
Marty
pingf
« Reply #2 on: October 08, 2010, 05:21:27 pm »
still cant work .
I can commit files , so this means that I can write , am I right ?
but the diff window's Read only checkbox for remote file is always checked and gray .... ???
