Author Topic: How to turn off word wrap when printing  (Read 3306 times)
Bertho
« on: October 17, 2010, 09:21:11 PM »
I am new to SlickEdit, changing from Code-Wright, and going through the learning experience.
I searched on the subject and saw a reply that version 15 under file/printing/general/ tab has an option to set the last column.
The trial version is 15.0.1.3 and I can not see that.
To get clean formatting and indenting when printing I want to turn off word wrap on printing and just lose the extra characters.
How can I do that without actually modifying the text file?
Thanks in advance,
Bertho
ScottW, VP of Dev
  • Hero Points: 64
Re: How to turn off word wrap when printing
« Reply #1 on: October 18, 2010, 02:26:26 PM »
We have a change request filed to turn off word wrap for printing, but we don't currently have that capability. The workaround is to do a block selection of the characters you want, then bring up the print dialog and then put a check in the "Selection only" checkbox.
Block selections can be done as follows:
  • Use the mouse to right-click and drag.
  • Use the select_block command (Ctrl+B or Edit → Select → Block ), then use the arrow keys to extend the selection, or use the mouse to click at the end of the selection.
