Author Topic: Transfer SE Core settings to my notebook  (Read 3883 times)
Paul001
« on: November 29, 2010, 11:34:53 pm »
How do I transfer SE Core settings to my notebook? I am interesting in transferring things such key bindings, colors, formatting, etc.
Thanks.
paul
Ryan
  • Hero Points: 77
Re: Transfer SE Core settings to my notebook
« Reply #1 on: November 30, 2010, 01:13:58 am »
What version of Core are you running?
If you are running Core 3.5.1 I would use the export/import preferences tool at Window > SlickEdit Preferences > Export/Import Preferences.  You can create a zip file with your setting which you can then load on your notebook with the same tool.  One note though, the machines do need to be the same platform in order to share settings.
Hope this helps,
Ryan
« Last Edit: November 30, 2010, 03:03:14 pm by Ryan »
