Author Topic: Eclipse can not lunch ( Windows Platform)  (Read 5096 times)
EulerMeng
« on: January 07, 2011, 02:53:03 am »
Dear All:
I installed SE Core for Eclipse (i copied sc_03060100_multi_full folder to dropins),
and now Eclipse won't launch.  :(
I took a look at the log and here's what I find:
!SESSION 2011-01-07 10:16:54.990 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_21
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2011-01-07 10:17:12.596
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: com.slickedit.eclipse.SlickEditSystem.getAlertGroupVisible(I)I
   at com.slickedit.eclipse.SlickEditSystem.getAlertGroupVisible(Native Method)
   at com.slickedit.swt.StatusIcon.createControl(StatusIcon.java:55)
   at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:102)
   at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createControl(DynamicToolBarContributionItem.java:208)
   at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:97)
   at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
   at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
   at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
   at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
   at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3830)
   at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3841)
   at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1124)
   at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
   at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:268)
   at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1010)
   at org.eclipse.jface.window.Window.create(Window.java:431)
   at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1208)
   at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
   at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
   at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
   at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
   at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
   at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
   at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
   at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
   at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
   at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
   at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
   at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
   at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
   at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
   at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
   at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
   at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Platform is Windows XP, and Eclipse version is Release 3.6.1 Last revised September 8, 2010
how can i solve it?
Thanks a lot
-Euler
Ryan
  • Hero Points: 77
Re: Eclipse can not lunch ( Windows Platform)
« Reply #1 on: January 07, 2011, 03:29:17 am »
Why did you install it like that?  Is there a reason you didn't install it the normal way, from the update site?
Even if you can't use the update site (if there is a problem with a firewall, for example) and you need to install from the zip file, you should still use the Eclipse installation mechanism to install from the zip file.  That should work fine.  Let me know if you need help doing that.
Hope this helps,
Ryan
