Author Topic: Weird characters in Build window  (Read 20443 times)
ypereto
Re: Weird characters in Build window
« Reply #15 on: September 07, 2011, 01:58:42 pm »
I'm running Ubuntu 11.04 and SlickEdit v16.0.2.0 64bit
I was able to fix this by changing the following settings:
1. Create a file named /home/<your user>/.slickedit/16.0.2/vslick.ini with the following contents
; This INI file is intended to contain SlickEdit environment
; variables.
[Environment]
LC_CTYPE=C
2. Set the def_build_shell macro to "/bin/sh -i"
Macro -> Set Macro Variable
Variable: def_build_shell
Value: /bin/sh -i
lwb78750
  • Senior Software Engineer, C++, Qt, C, etc...
« Reply #16 on: September 08, 2011, 08:25:28 pm »
Wow! I put up with the same problem for over a year! (on Linux) Thanks for the solution!
murali
« Reply #17 on: November 03, 2012, 05:40:21 am »
How do we fix this problem for Windows? I am running SlickEdit 2012 (v17.0.2.0 64-bit).
thanks,
Murali
  • Hero Points: 291
« Reply #18 on: November 03, 2012, 08:26:55 am »
@murali: Ususally there is no such problem with Windows. At least when using native tools.
Question is what's your setup showing the problem and what's the problem in more detail.
murali
« Reply #19 on: November 03, 2012, 06:50:14 pm »
I am using g++ (GCC) 4.3.4 20090804 (release) 1 as the compiler and it is part of Cygwin.
This is the same output, I get. Let me know if any additional details are required..
C:\test\foo>"c:\program files\slickeditv17.0.2 x64\win\vsbuild" -signal 55112 -command make -f "foo" CFG=Debug
VSLICKERRORPATH="C:\test\foo"
make -f foo CFG=Debug
cc     foo.c   -o foo
foo.c:40: warning: useless storage class specifier in empty declaration
g++ -c   -g -o "Debug/foo.o"  foo.c
foo.c:40: warning: ‘typedef’ was ignored in this declaration
foo.c: In function ‘char* bar(uint32)’:
foo.c:109: warning: deprecated conversion from string constant to ‘char*’
foo.c:111: warning: deprecated conversion from string constant to ‘char*’
foo.c:113: warning: deprecated conversion from string constant to ‘char*’
foo.c:115: warning: deprecated conversion from string constant to ‘char*’
g++  -g -o "Debug/foo.exe" Debug/foo.o
and the project template I used was
TemplateName="GNU C/C++"
thanks,
Murali
« Last Edit: November 03, 2012, 07:16:32 pm by murali »
  • Hero Points: 291
« Reply #20 on: November 04, 2012, 10:42:21 am »
@murali: I already assumed you're running a GNU compiler. Beware that cygwin emulates a UNIX environment.
Depending on the shell you're using (sh.exe / ash.exe ?) you should try to setup your environment ie. 'LANG' environment variable according to the previous postings.
I'm not sure about the details but maybe adding/modifying '<cygwin path>/etc/profile' is also a possibilty.
I think you can verify if the change works with 'set' or 'printenv' running the shell make is using.
The corresponding SHELL environment variable evaluated by make defaults to '/bin/sh' (see 'make' manual '5.3.2 Choosing the Shell')
Hope it helps.
Good luck, HS2
