Author Topic: Change make into mingw32-make.exe  (Read 10671 times)
ehab
  • Hero Points: 15
  • coding with SE is like playing music
« on: May 04, 2011, 09:53:26 am »
did you know you can change the default make to mingw32-make.exe
That is by :
1- Click on Macro | Set Macro Set Macro Variable...
2- In the Variable type edit box type : def_default_make_program
3- Then in value replace make with mingw32-make.exe
you may need to add paths to your win env. or add the complete path in value edit box.
ehab
« Last Edit: May 04, 2011, 02:41:11 pm by ScottW, VP of Dev »
