Author Topic: SE 2011 Issues  (Read 8044 times)
3JB
  • Guest
SE 2011 Issues
« on: May 13, 2011, 04:56:43 pm »
I recently upgraded from SE v15 (2010) to SE v16 (2011).
So far, I am having the following issues:
1. Every time I open SE, I get two error windows.  The first is a popup window and states "Invalid argument file=MenuCustomizationHandler.ex offset=2983".  The second is a SE stack message with the message posted at the end of this post.  When SE opens, it opens my last project file.  Closing and then reopening the project file does not produce these errors.
2. Every time I open SE, my Perforce configuration does not get initialized.  Closing and then reopening the project file initializes Perforce correctly.
3. Every time I close and then reopen SE, my custom menu goes away.  My custom menu calls some macro functions, and is placed on the _mdi_menu. I have re-added my menu commands several times.  Each time, the menu heading remains, but all menu items are removed when SE is closed.
Thanks for the help.
SE stack message:
Invalid argument
MenuCustomizationHandler.ex 2983 sc.controls.customizations.MenuCustomizationHandler.findCaptionInCaptionList(
   1:   ._typename()=sc.controls.customizations.MenuCustomizationHandler
   1:   .m-modFile=C:\Users\jbargman\Documents\My SlickEdit Config\16.0.0\userMenus.xml
   1:   .m-elementName=Menu
   1:   .m-categoryName=Menus
   2:   _mdi_menu>Launch>Firefox
   3:   <empty>
   4:   -1
   5:   -1
   p_window_id: 78
   p_object: OI_EDITOR
   p_name:
MenuCustomizationHandler.ex 3416 sc.controls.customizations.MenuCustomizationHandler.findPrevAndNextItems(
   2:   FIRST_ITEM
   3:   _mdi_menu>Launch>Firefox
   4:   <empty>
   5:   -2
   6:   23686
   7:   -1
   p_window_id: 5
   p_object: OI_FORM
   p_name:
CustomizationHandler.ex 1607 sc.controls.customizations.CustomizationHandler.determineItemPosition(
   2:   FIRST_ITEM
   4:   <empty>
   5:   0
   p_window_id: 5
   p_object: OI_FORM
   p_name:
3JB
  • Guest
Re: SE 2011 Issues
« Reply #1 on: May 13, 2011, 04:57:57 pm »
MenuCustomizationHandler.ex 3333 sc.controls.customizations.MenuCustomizationHandler.insertMenuItem(
   2:   ._typename()=sc.controls.customizations.MenuModification
   2:   .m-command=launch-program 5
   2:   .m-caption=iTunes
   2:   .m-message=
   2:   .m-action=0
   2:   .m-prev=FIRST_ITEM
   2:   .m-next=_mdi_menu>Launch>Firefox
   2:   .m-parentCaption=_mdi_menu>Launch
   2:   .m-help=
   2:   .m-categories=
   2:   .m-subMenu=0
   3:   :[_mdi_menu>View>Language View Options... ]=571474081 571474071
   3:   :[_mdi_menu>Tools>Calculator]=571474259 571474252
   3:   :[_mdi_menu>Window>Previous]=571474318 571474311
   3:   :[_mdi_menu>Tools>Imports>Add Import]=571474292 571474290
   3:   :[_mdi_menu>Edit>Copy Word]=571473991 571473981
   3:   :[_mdi_menu>Edit>Select]=571473996 571473981
   3:   :[_mdi_menu>Edit>Other>Shift Right]=571474022 571474016
   3:   :[_mdi_menu>Search>Last Find/Grep List]=571474070 571474041
   3:   :[_mdi_menu>Edit>Delete>To End of Line]=571474008 571474005
   3:   :[_mdi_menu>File>Open...   F7]=571473924 571473921
   3:   :[_mdi_menu>Help>Macro Functions by Category]=571474340 571474329
   3:   :[_mdi_menu>Tools>Version Control>Properties...]=571474276 571474264
   3:   :[_mdi_menu>Tools>Version Control>Difference...]=571474275 571474264
   3:   :[_mdi_menu>Macro>Set Macro Variable...]=571474233 571474223
   3:   :[_mdi_menu>Debug>Debugger Options...]=571474187 571474137
   3:   :[_mdi_menu>Project>Open Other Workspace>Tornado Workspace...]=571474105 571474101
   3:   :[_mdi_menu>Edit>Insert Literal...]=571473994 571473981
   3:   :[_mdi_menu>Edit>Select>Block]=571473998 571473996
   3:   :[_mdi_menu>Help>Product Updates>New Updates...]=571474352 571474351
   3:   :[_mdi_menu>Project>Organize All Workspaces...]=571474116 571474098
   3:   :[_mdi_menu>File>File Manager>Repeat Command...]=571473976 571473950
   3:   :[_mdi_menu>Build>Previous Error]=571474129 571474126
   3:   :[_mdi_menu>Document>Format Columns]=571474202 571474188
   3:   :[_mdi_menu>Debug>Windows>Registers]=571474146 571474138
   3:   :[_mdi_menu>Debug>Set Watchpoint]=571474185 571474137
   3:   :[_mdi_menu>File>File Manager>Delete]=571473957 571473950
   3:   :[_mdi_menu>Tools>Version Control>Unlock]=571474269 571474264
   3:   :[_mdi_menu>Macro>Selected Form...]=571474247 571474223
   3:   :[_mdi_menu>Project>Open Other Workspace>Xcode Project...]=571474110 571474101
   3:   :[_mdi_menu>File>Print...]=571473945 571473921
   3:   :[_mdi_menu>View>Tool Windows>Customize...]=571474086 571474085
   3:   :[_mdi_menu>File>FTP]=571473937 571473921
   3:   :[_mdi_menu>Tools>Spell Check>Check Word at Cursor]=571474305 571474301
   3:   :[_mdi_menu>Debug>Windows>Breakpoints]=571474145 571474138
   3:   :[_mdi_menu>Window>Cascade]=571474312 571474311
   3:   :[_mdi_menu>Search>Incremental Search]=571474048 571474041
   3:   :[_mdi_menu>Edit>Other>Adjust Block]=571474024 571474016
   3:   :[_mdi_menu>Help>-]=571474362 571474329
   3:   :[_mdi_menu>Tools>Spell Check>-]=571474307 571474301
   3:   :[_mdi_menu>Debug>Attach Debugger>GDB>Debug Executable (GDB)...]=571474158 571474155
   3:   :[_mdi_menu>Project>Open Files from Project...]=571474121 571474098
   3:   :[_mdi_menu>Search>Go to Offset...]=571474054 571474041
   3:   :[_mdi_menu>File>FTP>Activate FTP]=571473939 571473937
   3:   :[_mdi_menu>File>FTP>Client]=571473941 571473937
   3:   :[_mdi_menu>Window>One Window]=571474325 571474311
   3:   :[_mdi_menu>Tools>-]=571474309 571474252
   3:   :[_mdi_menu>Tools>Quick Refactoring>Replace Literal with Constant...]=571474289 571474285
   3:   :[_mdi_menu>Project>Open Workspace...]=571474100 571474098
   3:   :[_mdi_menu>File>FTP>Start New Connection...]=571473938 571473937
   3:   :[_mdi_menu>File>File Manager>Global Find...]=571473978 571473950
   3:   :[_mdi_menu>Tools>Imports>Organize Imports]=571474291 571474290
   3:   :[_mdi_menu>Debug>Show Next Statement]=571474177 571474137
   3:   :[_mdi_menu>File>File Manager>Files>Unlist Selected]=571473969 571473967
   3:   :[_mdi_menu>Macro>Load and Run Form   Shift+Space]=571474248 571474223
   3:   :[_mdi_menu>Edit>Other>Block Insert Mode]=571474040 571474016
   3:   :[_mdi_menu>View>Expand/Collapse Block]=571474095 571474071
   3:   :[_mdi_menu>File>File Manager>Files>Unlist All]=571473968 571473967
   3:   :[_mdi_menu>Tools>Imports>-]=571474293 571474290
   3:   :[_mdi_menu>Macro>Header - Function]=571474365 571474223
   3:   :[_mdi_menu>Document>Justify...]=571474220 571474188
   3:   :[_mdi_menu>Debug>Step Instruction]=571474174 571474137
   3:   :[_mdi_menu>Project>Open Other Workspace>Flash Project...]=571474111 571474101
   3:   :[_mdi_menu>Help>Keys Help]=571474337 571474329
   3:   :[_mdi_menu>Debug>Windows>Autos]=571474142 571474138
   3:   :[_mdi_menu>File>FTP>Upload]=571473940 571473937
   3:   :[_mdi_menu]=571473920
   3:   :[_mdi_menu>Edit>Other>Copy UCN As Unicode]=571474028 571474016
   3:   :[_mdi_menu>Document>Format Paragraph]=571474200 571474188
   3:   :[_mdi_menu>Tools>Version Control>Setup...]=571474279 571474264
   3:   :[_mdi_menu>Project>Dependencies...]=571474124 571474098
   3:   :[_mdi_menu>Edit>Complete Previous Word]=571474011 571473981
   3:   :[_mdi_menu>Edit>Indent]=571474014 571473981
   3:   :[_mdi_menu>Window>Tile]=571474313 571474311
   3:   :[_mdi_menu>Document>Edit Associated File]=571474193 571474188
   3:   :[_mdi_menu>Project>Open Other Workspace]=571474101 571474098
   3:   :[_mdi_menu>Edit>Copy]=571473988 571473981
   3:   :[_mdi_menu>Debug>Windows>Call Stack]=571474139 571474138
   3:   :[_mdi_menu>View>Show All]=571474097 571474071
   3:   :[_mdi_menu>Search>-]=571474069 571474041
   3:   :[_mdi_menu>Window>Link Window...]=571474327 571474311
   3:   :[_mdi_menu>Tools>Quick Start Configuration...]=571474254 571474252
   3:   :[_mdi_menu>Macro>Insert Form or Menu Source...]=571474251 571474223
   3:   :[_mdi_menu>Project>New...]=571474099 571474098
   3:   :[_mdi_menu>File>Save As...]=571473930 571473921
   3:   :[_mdi_menu>View>Full Screen]=571474087 571474071
   3:   :[_mdi_menu>Document]=571474188 571473920
   3:   :[_mdi_menu>Build>Go to Error or Include]=571474130 571474126
   3:   :[_mdi_menu>Document>XML/HTML Formatting>Enable XML/HTML Formatting]=571474214 571474211
   3:   :[_mdi_menu>Edit>Other>Copy Unicode As>C++ (UTF-16 \xHHHH)]=571474030 571474029
   3:   :[_mdi_menu>Tools>Spell Check>Check Selection]=571474304 571474301
   3:   :[_mdi_menu>Project>Insert Project into Workspace...]=571474123 571474098
   3:   :[_mdi_menu>File>File Manager>Append File List...]=571473952 571473950
   3:   :[_mdi_menu>Document>Previous Buffer]=571474190 571474188
   3:   :[_mdi_menu>Search>Previous Occurrence]=571474045 571474041
   3:   :[_mdi_menu>Project>Open Other Workspace>NAnt .build File...]=571474108 571474101
   3:   :[_mdi_menu>Edit>Other]=571474016 571473981
   3:   :[_mdi_menu>Window>Next]=571474317 571474311
   3:   :[_mdi_menu>Tools>Version Control>Check Out]=571474267 571474264
   3:   :[_mdi_menu>Tools>ASCII Table]=571474261 571474252
   3:   :[_mdi_menu>Window>Split Vertically]=571474323 571474311
3JB
  • Guest
Re: SE 2011 Issues
« Reply #2 on: May 13, 2011, 04:58:29 pm »
   4:   :[571473920][0]=_mdi_menu>File
   4:   :[571473920][1]=_mdi_menu>Edit
   4:   :[571473920][2]=_mdi_menu>Search
   4:   :[571473920][3]=_mdi_menu>View
   4:   :[571473920][4]=_mdi_menu>Project
   4:   :[571473920][5]=_mdi_menu>Build
   4:   :[571473920][6]=_mdi_menu>Debug
   4:   :[571473920][7]=_mdi_menu>Document
   4:   :[571473920][8]=_mdi_menu>Macro
   4:   :[571473920][9]=_mdi_menu>Tools
   4:   :[571473920][10]=_mdi_menu>Window
   4:   :[571473920][11]=_mdi_menu>Help
   4:   :[571473920][12]=_mdi_menu>Launch
   4:   :[571473920][13]=<empty>
   4:   :[571474098][0]=_mdi_menu>Project>New...
   4:   :[571474098][1]=_mdi_menu>Project>Open Workspace...
   4:   :[571474098][2]=_mdi_menu>Project>Open Other Workspace
   4:   :[571474098][3]=_mdi_menu>Project>Close Workspace
   4:   :[571474098][4]=_mdi_menu>Project>Organize All Workspaces...
   4:   :[571474098][5]=_mdi_menu>Project>Workspace Properties...
   4:   :[571474098][6]=_mdi_menu>Project>-
   4:   :[571474098][7]=_mdi_menu>Project>Add New Item from Template...
   4:   :[571474098][8]=_mdi_menu>Project>-
   4:   :[571474098][9]=_mdi_menu>Project>Open Files from Project...
   4:   :[571474098][10]=_mdi_menu>Project>Open Files from Workspace...
   4:   :[571474098][11]=_mdi_menu>Project>Insert Project into Workspace...
   4:   :[571474098][12]=_mdi_menu>Project>Dependencies...
   4:   :[571474098][13]=_mdi_menu>Project>Project Properties...
   4:   :[571473959][0]=_mdi_menu>File>File Manager>Select>All
   4:   :[571473959][1]=_mdi_menu>File>File Manager>Select>Deselect All
   4:   :[571473959][2]=_mdi_menu>File>File Manager>Select>InvertSelect
   4:   :[571473959][3]=_mdi_menu>File>File Manager>Select>Attribute...
   4:   :[571473959][4]=_mdi_menu>File>File Manager>Select>Extension...
   4:   :[571473959][5]=_mdi_menu>File>File Manager>Select>Highlight
   4:   :[571473959][6]=_mdi_menu>File>File Manager>Select>Deselect Highlight
   4:   :[571473921][0]=_mdi_menu>File>New...
   4:   :[571473921][1]=_mdi_menu>File>New Item from Template...
   4:   :[571473921][2]=_mdi_menu>File>Open...   F7
   4:   :[571473921][3]=_mdi_menu>File>Open URL...
   4:   :[571473921][4]=_mdi_menu>File>Close
   4:   :[571473921][5]=_mdi_menu>File>Close All
   4:   :[571473921][6]=_mdi_menu>File>-
   4:   :[571473921][7]=_mdi_menu>File>Save
   4:   :[571473921][8]=_mdi_menu>File>Save As...
   4:   :[571473921][9]=_mdi_menu>File>Save All
   4:   :[571473921][10]=_mdi_menu>File>Revert
   4:   :[571473921][11]=_mdi_menu>File>Change Directory...
   4:   :[571473921][12]=_mdi_menu>File>-
   4:   :[571473921][13]=_mdi_menu>File>Backup history for ...
   4:   :[571473921][14]=_mdi_menu>File>-
   4:   :[571473921][15]=_mdi_menu>File>FTP
   4:   :[571473921][16]=_mdi_menu>File>-
   4:   :[571473921][17]=_mdi_menu>File>Print...
   4:   :[571473921][18]=_mdi_menu>File>Insert a File...
   4:   :[571473921][19]=_mdi_menu>File>Write Selection...
   4:   :[571473921][20]=_mdi_menu>File>Template Manager...
   4:   :[571473921][21]=_mdi_menu>File>Export to HTML...
   4:   :[571473921][22]=_mdi_menu>File>File Manager
   4:   :[571473921][23]=_mdi_menu>File>-
   4:   :[571473921][24]=_mdi_menu>File>Exit
   4:   :[571474252][0]=_mdi_menu>Tools>Options...
   4:   :[571474252][1]=_mdi_menu>Tools>Quick Start Configuration...
   4:   :[571474252][2]=_mdi_menu>Tools>-
   4:   :[571474252][3]=_mdi_menu>Tools>Regex Evaluator...
   4:   :[571474252][4]=_mdi_menu>Tools>OS Shell
   4:   :[571474252][5]=_mdi_menu>Tools>OS File Browser...
   4:   :[571474252][6]=_mdi_menu>Tools>Calculator
   4:   :[571474252][7]=_mdi_menu>Tools>Add Selected Expr
   4:   :[571474252][8]=_mdi_menu>Tools>ASCII Table
   4:   :[571474252][9]=_mdi_menu>Tools>Generate GUID...
   4:   :[571474252][10]=_mdi_menu>Tools>-
   4:   :[571474252][11]=_mdi_menu>Tools>Version Control
   4:   :[571474252][12]=_mdi_menu>Tools>-
   4:   :[571474252][13]=_mdi_menu>Tools>C++ Refactoring
   4:   :[571474252][14]=_mdi_menu>Tools>Quick Refactoring
   4:   :[571474252][15]=_mdi_menu>Tools>Imports
   4:   :[571474252][16]=_mdi_menu>Tools>Generate debug
   4:   :[571474252][17]=_mdi_menu>Tools>-
   4:   :[571474252][18]=_mdi_menu>Tools>Sort...
   4:   :[571474252][19]=_mdi_menu>Tools>Beautify...
   4:   :[571474252][20]=_mdi_menu>Tools>File Merge...
   4:   :[571474252][21]=_mdi_menu>Tools>File Difference...
   4:   :[571474252][22]=_mdi_menu>Tools>Spell Check
   4:   :[571474252][23]=_mdi_menu>Tools>-
   4:   :[571474252][24]=_mdi_menu>Tools>Tag Files...
   4:   :[571474235][0]=_mdi_menu>Macro>Slick-C® Profiler>Begin Profiling
   4:   :[571474235][1]=_mdi_menu>Macro>Slick-C® Profiler>Finish Profiling...
   4:   :[571474235][2]=_mdi_menu>Macro>Slick-C® Profiler>Profile Keystroke...
   4:   :[571474235][3]=_mdi_menu>Macro>Slick-C® Profiler>Save...
   4:   :[571474235][4]=_mdi_menu>Macro>Slick-C® Profiler>Load...
   4:   :[571474005][0]=_mdi_menu>Edit>Delete>Word
   4:   :[571474005][1]=_mdi_menu>Edit>Delete>Line
   4:   :[571474005][2]=_mdi_menu>Edit>Delete>To End of Line
   4:   :[571474005][3]=_mdi_menu>Edit>Delete>Selection
   4:   :[571474005][4]=_mdi_menu>Edit>Delete>All
   4:   :[571474016][0]=_mdi_menu>Edit>Other>Lowcase
   4:   :[571474016][1]=_mdi_menu>Edit>Other>Upcase
   4:   :[571474016][2]=_mdi_menu>Edit>Other>Capitalize
   4:   :[571474016][3]=_mdi_menu>Edit>Other>-
   4:   :[571474016][4]=_mdi_menu>Edit>Other>Shift Left
   5:   0
   6:   0
   p_window_id: 5
   p_object: OI_FORM
   p_name:
MenuCustomizationHandler.ex 4144 sc.controls.customizations.MenuCustomizationHandler.applyMod(
   2:   .m-message=
   2:   .m-action=0
   2:   .m-help=
   2:   .m-categories=
   2:   .m-subMenu=0
   5:   <empty>
   p_window_id: 5
   p_object: OI_FORM
   p_name:
Sandra
  • Hero Points: 36
Re: SE 2011 Issues
« Reply #3 on: May 13, 2011, 05:28:54 pm »
The stack has been reported and will be fixed with the first revision of the v16 hot fix.  1 and 2 are probably the same issue.  I will update this thread when the hot fix has been posted, so you can verify if it fixes your issue.
Cannot speak for the Perforce issue, but I'll make sure someone who can sees this thread.
  • Hero Points: 153
Re: SE 2011 Issues
« Reply #4 on: May 13, 2011, 05:30:32 pm »
You are using the 32-bit version, correct?
3JB
  • Guest
Re: SE 2011 Issues
« Reply #5 on: May 13, 2011, 05:32:29 pm »
Yes, 32-bit version on Windows7.
Thanks!
  • Hero Points: 153
Re: SE 2011 Issues
« Reply #6 on: May 13, 2011, 05:34:38 pm »
OK.  Had to ask.
Now I have to ask this: Are you sure it is not initialized?  I have seen instances where the project toolwindow just didn't refresh for some reason.  Have you tried menu items?
3JB
  • Guest
Re: SE 2011 Issues
« Reply #7 on: May 13, 2011, 05:39:57 pm »
I'm not sure what you are asking exactly.  If you are asking about my custom menu, there are no items on the menu after I close and reopen SE.  After I add them, each one works as desired.
  • Hero Points: 153
Re: SE 2011 Issues
« Reply #8 on: May 13, 2011, 05:53:19 pm »
Are the items on the Version Control menu enabled?
3JB
  • Guest
Re: SE 2011 Issues
« Reply #9 on: May 13, 2011, 05:58:22 pm »
Yes, they are enabled and it appears as if it is already initialized.  If I try to check out a file via SE, I get a popup message that says "You must first open a project (Tools...Version Control...Setup)".  When I do this, I can then check out a file via SE as normal.
This occurs each time SE 2011 starts up, and did not occur with SE 2010.
Thanks again.
Sandra
  • Hero Points: 36
Re: SE 2011 Issues
« Reply #10 on: May 17, 2011, 05:21:27 pm »
The cumulative v16 hot fix now includes fixes for your menu issues - both the stack and the loss of your custom menu.  Get the hot fix here:  http://www.slickedit.com/index.php?option=com_content&view=article&id=293.
3JB
  • Guest
Re: SE 2011 Issues
« Reply #11 on: May 17, 2011, 05:35:27 pm »
My 3 issues seem to be resolved.
Thank you!
